AutoComplete BIM data
Commands
BIMAUTOMATCH
About the AutoComplete BIM data
Instead of assigning compositions to every element manually, the BIMAUTOMATCH command detects the difference between interior and exterior walls and their respective composition and automatically assigns it to other walls. It can also make distinctions between different floors, different sides of the building, walls with a balcony, etc.
Note: Before you use the BIMAUTOMATCH command make sure that you have Bimified (
) everything. AutoMatch works best with a fully Bimified model.
) everything. AutoMatch works best with a fully Bimified model.AutoComplete BIM data in one file
- Type BIMAUTOMATCH in the Command line and press Enter.
The Auto Match dialog box appears.
- Select one of the following:
- Compositions: Copy compositions.
- Window Parameters: Copy window parameters.
- BIM Properties: Copy BIM Properties.
- Stair Parameters: Copy Stair Parameters.
- Under Select Source, choose Autocomplete.
- If the file contains multiple buildings, the BIMAUTOMATCH command asks you to define the source building.
Select a building and press Enter.
- If BIMAUTOMATCH finds a logical distinguishing feature between objects it will automatically use this. When it can not, the BIMAUTOMATCH command asks you to define the source composition or window.
AutoComplete BIM data with an external file
- Window Parameters: Copy parameters of windows.
- Stair Parameters: Copy properties of stairs.
- Under Select Source, choose External file.
- Select the source file and click Open.
Select the building and press Enter.
Procedure: using autocomplete in one file
- Open up a file to start from. Here we use a basic rectangular building that looks like this:
Note: No BIM data or compositions should be added yet. - Add the compositions that you want. Don't do this for all your elements, but only for one element of each type. In our example we give a composition to 1 outer wall, 1 inner wall, 1 floor slab and the roof:
Note: It could be that you have different types of outer walls, for example the wall facing north that needs more insulation. In this case, you give one of these northern walls a different composition. - In this example, we also want to adjust the parameters of our windows. Select only one of the windows and change the parameter you want in the Properties panel.
The window before changes.
Changing the PlacementDepth value in the Properties panel of the window.
The window after the changes. - Type BIMAUTOMATCH and press Enter. The Auto Match dialog box appears.
- Check the boxes from Compositions and Window Parameters to have the compositions and the window parameters that we chose to be completed in our entire drawing.
- Select Autocomplete. The compositions and window parameters within your file are automatically copied. The drawing looks like this:
By using BIMAUTOMATCH command, we very quickly have all our compositions and window parameters as we want them, without having to worry about forgetting anything.
Note: You can see that different types of outer walls have no problems. All the walls facing north have been given the correct adjusted composition.
Procedure: using autocomplete with an external file
- Open up a project that is similar in style to another project that you already finished. In this case, we take another rectangular building, similar to the one we looked at before:
- Select External file.
- Select the file that we made in the previous procedure. The compositions and window parameters from the external file will be copied to your new file. The drawing looks like this:
Note: It can be handy to make a library of building styles with their typical compositions, in order to use the BIMAUTOMATCH command with external files in a very efficient way.
