Exploring the BIM interface
User interface
The BricsCAD® BIM interface includes all tools, commands, and settings required to create and edit building elements. Start by creating building elements, opening an existing drawing or importing a building model.
Interface elements
- Toolbar
- BIM Ribbon
- Working with Document Tabs
- Tool Panel
- LookFrom control
- UCS Icon
- Model and Layout Tabs
- Command line
- Status Bar
Toolbar
In BricsCAD®, toolbars are arranged in collections of similar functions within a bar of tools. Each function is displayed with an icon and is categorized by topic. Toolbars are available for all command categories. For example, a BIM toolbar is one of the tool categories available in BricsCAD® BIM. This toolbar includes the most used BIM tools for modeling. It is possible to customize existing toolbars or create your own custom toolbars.
By default, the Access (Easy) toolbar is shown on top of the screen.
BIM Ribbon
A ribbon consists of tabs (2) that group different tab panels (3). Each tab panel contains a series of command buttons and flyouts.
Click the File menu button (1) to access BricsCAD®'s File menu options.
Type in a string in the Search bar (4) to locate tools in the Ribbon.
Click the Interface Settings button (5) located at the top-right of the Ribbon to easily modify the interface via the Interface Settings dialog box (see the Interface Settings dialog box related article).
| Creating a ribbon tab |
Open the Customize dialog box (CUI command) and click the Ribbon tab. Right-click the Ribbon tabs group and choose Append ribbon tab in the context menu. ![]() Fill out the fields in the Add Ribbon Tab dialog box: ![]() Label: Caption on the ribbon tab. Title: Used in the Select Ribbon Tab dialog when selecting ribbon tabs for a workspace. ID: A unique name to identify the ribbon tab. |
| Editing a ribbon tab |
Open the Customize Dialog box and click the Ribbon tab. Expand the Ribbon tabs group and you can edit each tab. |
| Creating a ribbon panel |
Open the Customize dialog box and click the Ribbon panels. Right-click the Ribbon panels group and choose Append ribbon panel in the context menu. ![]() Fill out the fields in the Add Ribbon Panel dialog box: ![]() Label: Caption of the panel in the ribbon. Title: Used in the Select Ribbon Panel dialog when selecting the panels for a ribbon tab. ID: A unique name to identify the ribbon panel. |
| Editing a ribbon panel |
Open the Customize dialog box and click the Ribbon panel. Expand the Ribbon panels group and you can edit each panel. |
Document tabs allow you to:
- Easily switch between all open drawings by clicking on drawing tabs (2).
- Drag and drop the tabs to change their order.
- Click the X icon at the right-hand side of the tab to close it.
- Right-click a document tab to display a context menu.
- Click the + icon (3) at the end of the document tab to open a new drawing.
- Access the Start Page by clicking on the Start tab (1).
Tool Panel
In BricsCAD® BIM the Tool panel is displayed on both sides of the workspace. The Tool panel consists of BIM panels. The BIM panels are dockable and thus they are movable. The panels can be moved to another docked panel using the drag and drop method.
By default, the Tool panel displays on the left-hand side the Tips, BIM Project Browser, and Structure panels, and on the right-hand side the Properties, Library, Details, BIM Compositions, BIM Profiles, Layers, Mechanical Browser, Bricsys 24/7, and BIM BCF.
These are the functions of the different dockable panels from the Tool panel:
![]() Tips |
The Tips panel gives general information about tools and commands. The tips can change depending on the active command. The tips can only be seen when the panel is open. |
![]() BIM Project Browser |
The BIM Project Browser panel allows you to easily navigate through the entire content of a project: models, sections, drawings, and schedules. See The BIM Project Browser article on how to use this panel. |
![]() Structure |
The Structure panel is an interactive tree that displays the entities in the current model. Using the configurable structure tree on the Structure panel, the BIM model can be organized in the way that you want to view the elements. Once you configured the tree, you can easily save this structured tree as a CST file. By default, the CST files are stored in the Support Folder. See the Structure panel article on how to use this panel. |
Properties |
The Properties panel shows all the properties of a selected element. You always have some general info first, the other different tabs within this panel depend on the type of element that is selected.
For example, here the selected item is a window and is colored by layer. You can adjust the properties as you like. See the Properties article to see how to work with this panel in more detail. |
![]() Library |
The Library panel gives a list of components that you have by default. You can simply click and drag these components into your drawing. At the top of the panel, you have the Add button that allows you to add a block to the library. For example, when you have made a window drawing, you can click this button to add it to the components library. This way, your window can be used as a component in all of your other drawings. |
Details |
In the Details panel you can:
BIM Compositions |
In the BIM Compositions panel, you find a library of predefined compositions you can assign to various solids of the BIM model by dragging them on. Assigning compositions to the elements in your model is a core step to increase the BIM model accuracy. Compositions can contain either multiple materials or a single ply. See the BIM Compositions article on how to use this panel in more detail. |
BIM Profiles |
The BIM Profiles panel shows a library of predefined profiles you can assign to linear solids by dragging them on. See the BIM Profiles article on how to work with this panel in more detail. |
Layers |
The Layers panel shows all the layers of your drawing. It shows you the current layer (1), you can change it by clicking left of another layer. It also shows if a layer is ON or OFF by the state of its light bulb icon (2). Other layer properties, such as color, linetype, etc., can be found and adjusted by scrolling to the right.
In this example the current layer is DOOR_FRAME and it is turned ON. |
Mechanical Browser |
The Mechanical Browser panel displays the hierarchy of components, features, arrays, parameters, and constraints for the current drawing. They are displayed in a tree-like form: you can expand and collapse every node to see its child nodes (for example, nested components).
The Mechanical Browser panel allows you to edit properties of a particular node, displayed at the bottom of the panel and calls different tools depending on what type is available in the context menu by right clicking a particular node. For example, in the image above you could add a description for the selected window. |
Bricsys 24/7 |
Login to your Bricsys 24/7 account here to collaborate on your project in the cloud. Bricsys® 24/7 makes project management, a collaboration between project teams, cloud computing security, and task automation possible. When logged on, you can see an overview of your in the cloud Projects, Folders and Documents as shown in the image below:
See the BricsCAD 24/7 panel article to see in detail how this panel works. |
BIM BCF |
Here you can import BCF (Bim Collaboration Format) files and connect to a BCF server. The BCF topics are listed in this panel.
The top part of the BCF panel shows all the topics and can look similar to the Library panel. The lower part of the BCF panel shows the currently active topic, with a bigger snapshot and the most common metadata: comment, author, status, etc. Double-clicking on an issue activates the topic. |
LookFrom control
The LookFrom control allows you to switch between a number of preset view orientations, such as orthographic views and isometric views. By default, the LookFrom control is displayed in the top right corner of the graphic screen. See the Using the LookFrom control article for more information.
UCS Icon
UCS stands for a User-defined Coordinate System. The UCS icon shows the nature of the current coordinate system.
The display of the icon is controlled through the UCSICON system variable and the position of the UCS icon is defined by the UCSICONPOSITION system variable.
At the bottom of the graphic screen sit the Model and one or more Layout tabs which allow you to easily switch between model space and paper space.
Model Tab
When you start a drawing session, your initial working area is called Model Space. The Model Space is an area in which you create two-dimensional and three-dimensional entities based on either the World Coordinate System (WCS) or User Coordinate System (UCS). You view and work in model space while using the Model tab (1).Layout Tab
Each drawing has at least one layout (2) and each layout is composed of one or more viewports. Each viewport can show a different part of the drawing at a different scale. The Paper Space is a work environment that provides the model space view at a given scale, depending on the size of the paper.
In each layout, you can add the entities needed to complete a printed copy of the drawing; title blocks, legends, frames, etc. These entities are only visible in the layout when you add. They are not visible in the other layouts or in the model space.
Click the New Layout button (3) to add a new layout.
Click the Manage model and layouts menu button (4) to display options to publish, create, copy and delete layouts.
Right-click a layout/model tab to open a context menu.
UCS in Layout Mode
In paper space of layout modes, a W letter appears in the UCS icon, which means the WCS is active.
Command line
- In the lower field, you can type the commands and BricsCAD® shows prompts, options and other information regarding the execution of commands here. If the Command line is closed, this information shows in the Status Bar.
- The command history displays in the upper field of the Command line panel.
By default, the Command line panel is floating (CMDLINEUSEMINIFRAME system variable = 1) and minimized to a single line. When executing a command, a number of prompt lines (set by the CLIPROMPTLINES system variable) are displayed temporarily and transparently on the graphic screen:
Click the up arrow at the right hand side to display the Prompt History window.
Press and hold the left mouse button on the edge of the right hand side, then drag to modify the length of the Command line panel.
Press and hold the left mouse button on the left hand side grip, then drag to modify the Command line panel's position.
Status Bar
The Status Bar sits along the bottom edge of the BricsCAD® application window. It contains a lot of information about the settings in the current drawing. All fields in the Status Bar are optional.
Click a field in the Status Bar (1) to toggle it ON/OFF. Right-click a field/ click the drop-down button (2) to display a context menu/settings for this field.
Click the Status Bar Menu button (3) to display the list of all fields. Click a field to toggle its display in the Status Bar.
