account
translation
Bricsys Help Center
Edit scale dialog box
The Edit Scale dialog box allows you to edit the name and the scale properties of a scale factor.
  1. Scale name
  2. Scale properties
Scale name
Edit the name by typing the new name.
Scale properties
Change the scale factor in paper (size when plotted) and/or drawing units.
Parent topic: BricsCAD
Parent topic: Dialog boxes
Related commands
  • SCALELISTEDIT command
  • -SCALELISTEDIT command
  • OBJECTSCALE command
  • -OBJECTSCALE command
  • PRINT command
  • PAGESETUP command
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
