Import Civil 3D dialog box
The Import Civil 3D dialog box allows you to create BricsCAD® civil entities from an AutoCAD® Civil 3D drawing.
- Convert from current drawing.
- Select drawing to import.
- Select All.
- Layer name template for Civil 3D objects.
- Import native CAD objects.
- Import Civil 3D labels as blocks.
Converts AutoCAD® Civil 3D objects in the current drawing.
Enables to enter drawing path or click the Select… button to select the drawing manually.
Note: When either the .dwg file is specified or the Convert From Current Drawing option is selected, AutoCAD® Civil 3D objects are listed in a tree view, organized by object type.
Select All
Enables to select all AutoCAD® Civil 3D objects in the selected drawing.
Enables to specify the Layer name template for imported AutoCAD® Civil 3D objects.
The following settings are available for defining the Layer name template:
- <Type> - includes AutoCAD® Civil 3D object type in the Layer name.
- <Name> - includes AutoCAD® Civil 3D object name in the Layer name.
- <SourceLayer> - Civil entities are created on same layer as source AutoCAD® Civil 3D objects.
If you want to draw BricsCAD® Civil entities on Layers, which names will consist of three sets: the type of the source Civil 3D object, the object name and the name of the Layer of the source AutoCAD® Civil 3D object, you need to write the following text in the field:
<Type>_<Name>_<SourceLayer>Import native CAD objects
Enables to import native CAD objects from the selected drawing in addition to AutoCAD® Civil 3D objects.
Enables to import AutoCAD® Civil 3D labels as blocks from the selected drawing.
