The Command line
The Command line is an optional dockable panel that is located by default at the bottom of the drawing area.
The Command line is a fast and efficient method to launch commands and to set system variables and user preferences.
BricsCAD prompts for user input in the Command line and reports the results of commands, such as DIST, AREA or LIST here.
When the Command line is closed, keyboard entries and command prompts display in the Status bar.
