Deactivate or revoke a BricsCAD license
Deactivating a license
Use this procedure to:
- Migrate a license to another computer.
- Permanently remove BricsCAD® from a computer.
- Reactivate BricsCAD® after installing a new hard disk, changing partitions, or upgrading the operating system.
To deactivate a BricsCAD® license, an internet connection is required. You cannot manually deactivate a license via another computer that is connected to the internet.
Note: You cannot deactivate:
- Single and volume licenses that are manually activated.
- Network licenses.
- Trial licenses.
The chart explains how to deactivate a BricsCAD® license. If it is not possible to deactivate a BricsCAD® license, you can revoke the license.
To deactivate a license:
- Launch the LICENSEMANAGER command. Click the Manage License option on the
Bricsys License Manager dialog box.
The License Manager dialog box displays.
- If your computer connects to the license server through a proxy server, click Proxy Settings... to configure the proxy settings.
- Click Deactivate...
- Click the Yes button on the confirmation dialog box to deactivate the
license.
The license is deactivated and can be activated on another computer.
Note: There is no limited number of deactivations. To move a license, always use the deactivate and reactivate options.
Revoking a license
Important:
- Only revoke a license if deactivation is not possible.
- The revoke possibility is limited to two per key.
- Deactivate a network license or a single or volume license manually that is manually activated.
- Reactivate BricsCAD® after a hard disk crash.
To revoke a license:
- Log in to the Bricsys website.
Make sure you log in with the Bricsys account containing your licenses.
- Click the My Account icon (
) and select Manage licenses (1)
in the menu.
- Hover over the license key of the license you want to revoke and click on the pencil icon
- Scroll down and click the X icon to revoke the license.
Note: If you are a Maintenance user, contact support to review your additional
revoke request.
