BricsCAD and AutoCAD feature comparison
BricsCAD versus AutoCAD® feature comparison.
Drawings
BricsCAD AutoCAD®
Lite Pro BIM Mechanical Ultimate LT Full
Native DWG file format (thru AutoCAD 2021)
Password Protection o o
eTransmit
Sheet Set Manager
Geographic Location
Drawing Compare
Cloud Collaboration
Interface
BricsCAD AutoCAD®
Dark and Light Color Themes
Industry standard commands, aliases, and variables
Command Line (Autocomplete, Midstring,
Clickable options)
Start tab
File (Drawing) tabs
Model and Layout tabs
Layout Manager o o
Menu bar
Toolbars
Ribbon
Tool Palettes
Contextual Right-click Menus
Contextual Quad Menu o o
Status Bar
Workspaces
Searchable Settings (Variables) Dialog Box o o
Lockable Interface
Clean Screen Mode
Drawing Explorer o o
Customizable User Interface (CUI)
Structure Browser o o
Selection, snap & track
BricsCAD AutoCAD®
Selection Filtering (QSELECT)
Add Selected
Select Similar
Selection Cycling
Entity Snaps (Osnaps)
Polar Tracking
Zintersection 3D snap o o
Nearest Distance o o
Adaptive Gridsnap o o
Real-time boundary detection o o
2D Dynamic UCS o o
3D Dynamic UCS o
Drawing tools
BricsCAD AutoCAD®
Line, Polyline, 3D Polyline, Spline, Ray, Xline
Multiline and Multiline Styles o
Circle, Arc, Ellipse, Elliptical Arc
Polygon, Rectangle, Region, Donut, Point
Helix o
2D Parameters, Constraints o
2D Autoconstrain 2 2
Annotation tools
BricsCAD AutoCAD®
Dimensions, Dimension Styles
Multi-leaders, Multi-leader Styles
Single and Multi-line text, Text Styles, Text Editor
Hatches, Gradients, Hatch/Gradient Editor
Wipeouts
Revision Clouds
Attributes, Attribute Editor
Tables, Table Styles
Fields
Date Extraction o
Data Linking
Annotation Scaling
Spell Check
Editing tools
BricsCAD AutoCAD®
Move, Copy, Rotate, Scale, Stretch, Mirror, Align
Trim, Extend, Lengthen, Break, Join
Fillet, Chamfer
CopyGuided o o
MoveGuided o o
Grip Edit
Properties panel
Manipulator (3D Gizmo) o
Draworder
Undo Per Entity (Property History) o o
Optimize o o
Simplify o o
Reference tools
BricsCAD AutoCAD®
Blocks, Block Editor
Dynamic Blocks 1 1 1 1 1
Block Face Camera o o
Blockify o o
Associative Arrays
Dwg (Xref) Attach, Clip, Bind, Edit
PDF Attach, Clip
Image Attach, Clip, Adjust, Transparency
Point Clouds Colormap o
Visualization tools
BricsCAD AutoCAD®
Layers, Layer States
Transparency
Visual Styles o
LookFrom (ViewCube™) o
Match Perspective o o
Lights o o
Sun Properties o o
Materials o o
Render o o
Animation Editor o o o
Walkthrough navigation o o
ANIPATH command o o
Modeling tools
BricsCAD AutoCAD®
ACIS Modeling o o
Solid and Surface Modeling o o
Solid Primitives o o
Mesh Primitives o o
Polysolid o o
Union, Subtract, Intersect, Interfere o o
Extrude, Revolve, Loft, Sweep, Thicken o o
Twist o o o
Fillet, Chamfer o o
Slice o o
Multi-slice o o o
T Connect, L Connect, Connect with Nearest o o o
Extract Edges o o
Direct modeling o o
Deformable (Freeform) Modeling o o
Audit, Simplify o
Stitch o o
3D Parameters, Constraints o o
3D Autoparametrize o o o
3D Blockify and ParametricBlockify o o o
3D Parametric Design Tables o o o
Section planes o o
Drawing Views o o
3D Threads o o o
Point Cloud Align o o o
Point Cloud Bubble Viewer o o o
Civil tools
BricsCAD AutoCAD®
TIN Surface Modeling o o o
TIN Volume Surface o o o
Grading o o o
Alignments o o o
Corridors o o o
Civil 3D Object Enabler o
Architectural Desktop Object Enabler o
CADWorx Object Enabler o
Architectural tools
BricsCAD AutoCAD®
BIM features o o o o
Structural Modeling Toolset o o o o
Project Database o o o o
Library Database o o o o
Site, Building and Stories o o o o
Windows and Doors o o o o
Fully Parametric BIM Component Creation o o o o o
3D Spaces o o o o
Quickdraw o o o o o
Quickbuilding o o o o o
Point Cloud Floor Detection o o o o o
Point Cloud Projection o o o o o
Point Cloud Geometry Detection o o o o o
Point Cloud FitPlanar (geometry detection) o o o o o
Propagate o o o o o
Custom BIM Properties o o o o o
Drawing Customizations o o o o o
Analytical Model o o o o o
Python Scripts (Beta) o o o o o
Mechanical tools
BricsCAD AutoCAD®
Mechanical Browser o o o
Parts Library o o
Piping o o o
Assembly Modeling o o o o o
Exploded Views o o o o o
Kinematic Analysis o o o o o
Bill of Materials o o o o o
Sheet Metal Design o o o o o
3D Solids to Sheet Metal Parts Conversion o o o o o
Corner Relief for Adjacent Edge Flanges o o o o o
Lofted Bends o o o o o
Coloring o o o o o
Diagnostic for Invalid Sheet Metal Features o o o o o
Batch Processing o o o o o
Import, export, output
BricsCAD AutoCAD®
Print/Plot
Publish/Batch Plot
CTB & STB Table Files
PC3 Printer Configuration Files
Named Page Setups
PDF Import, Export
DAE Import, Export o o
IFC Import, Export o o o o
3DM Import, Export o o o
LandXML Import, Export o o o
RFA Import o o o o o
SKP Import o o o
DGN Import
RVT Import o o o o o
DWF Export
SVG Export o o
FBX Export o o
STL Export o
Point Cloud Export o o o
Additional formats available with BricsCAD Communicator
o o o
Programming
BricsCAD AutoCAD®
ActiveX o
Entity data editor o o
Script Recorder o
Full LISP Support (vl, vlr, vla and vlax) o
Solutions Development System (SDS/ADS) o
DCL engine o
COM API o o
Visual Basic for Applications (VBA) o o o
VBA DVB projects support o o o
.NET o o
BRX (ARX) o o
TX (Teigha eXtensions) o o
CUI menu files support, with Diesel expressions
Licensing
BricsCAD AutoCAD®
Multi-platform Licenses o o
Perpetual o o
Perpetual + Maintenance o o
Subscription
Network Multi-user o o
Volume (Perpetual) o o
Academic
(1) You can manipulate dynamic block insertions but you cannot create dynamic block definitions.
(2) You can automatically apply geometric constraints but you cannot automatically apply a combination of geometric and dimensional constraints.
