Quick guide on using a network license
In general, Bricsys Network License Server downloading, deployment and configuration is a duty for the network/system administrator.
Server machine actions
- Download the Bricsys Network License Server from here and install it with default settings.
Info related to server security policies:
After installation, the RLM.exe must be allowed to use 3 ports: 5053 for the license, 5054 for the web UI, and a dynamically allocated port by Windows for the ISV server which can be set fixed after activation as described in the Advanced configurations article.
- When the Activate New Network License dialog box activation dialog is displayed, use the license key from your Bricsys account. See also the Where can I find my licenses? article.
The Network License Manager tool is in the C:\Program Files\Bricsys\Bricsys Network License Server\NetworkLicenseManager.exe folder and must be able to reach the license.bricsys.com/actpro port 80.
- The Reprise License Server Administration page is on localhost:5054.
Client machine actions
The client machine must be:
- In the same LAN with the Bricsys Network License Server, physically or by VPN connection.
- Able to communicate with the Bricsys Network License Server on port 5053 by the TCP/UDP protocol.
- Install BricsCAD® with default settings.
- Start BricsCAD® and activate the Network License: <servername>/<ip number> and <port>.
There may be no need for this as BricsCAD® will check the network for a license server at the start.
