BricsCAD system requirements
System requirements and recommendations for Microsoft Windows and Linux PCs, and Apple Macs.
Supported Operating Systems
  • Windows 8.1, 10, 11 (x64)
  • Ubuntu V20.04 and higher versions that are still supported by canonical (if you want a stable experience, LTS tends to be a good choice)
  • openSUSE builds, later than April 2020
  • Fedora builds, later than April 2020
  • macOS 10.15 or higher: Catalina (macOS 10.15), Big Sur (macOS 11), Monterey (macOS 12)
Note:
  • Microsoft Extended Support program for Windows 8.1 has ended on 10 January 2023. Windows 8.1 support for BricsCAD® will end in Oct 2023.
Minimum CPU:
  • Intel® Core™ i5
  • AMD Ryzen™ 5
Recommended CPU:
  • Intel® Core™ i7
  • Intel® Core™ i9
  • AMD Ryzen™ 7
  • AMD Ryzen™ 9
The CPU with the highest single-thread performance rating will always excel with BricsCAD®.
Additional CPU cores will bring in higher performance, as more and more functions gets multithreaded computation in BricsCAD®.
Note:
  • Intel® Xeon® and AMD Ryzen™ Threadripper™ CPUs: These top-tier workstation CPUs support large on-chip memory cache, more PCIe® I/O lanes and multi-channel, high speed memory architectures.
  • Since V21.2.06, BricsCAD® (Mac) works on Rosetta (Intel emulation on M1 chips). A native M1 build is planned in a future version.
Minimum System Memory:
8 GB
Recommended System Memory:
  • 16 GB
For maximum performance, determine the memory configuration of your PC and ensure that each memory channel on the motherboard is populated with at least one memory module.
Minimum Disk Space:
2 GB for BricsCAD® Ultimate, installed
Recommended Disk Space:
(As needed)
We recommend PCI-E NVME as system drives, for both BricsCAD® and Windows. Drawings and support files can reside on slower mechanical hard disk drives, if necessary.
Note: Solid-state disks can be up to 10x faster reading and 20x faster writing data than a mid-range hard disk drive
Minimum Display System:
  • Full HD (1920 x 1080) True Color display and a graphics card with 1 GB VRAM
  • Apple Mac Displays
Recommended Display System:
  • Multiple UHD (3840 x 2160) or 4k True Color displays, with a PCIe® graphics card w/GPUs and 4 GB VRAM
  • Apple Mac Retina (4K and 5K) Displays
On Microsoft Windows systems, most graphics cards & GPUs from NVIDIA, AMD and Intel® are supported.
On Linux systems, most graphics cards and GPUs from NVIDIA and AMD are supported.
On Mac systems, native Apple display hardware is supported.
BricsCAD®’s non-wireframe display modes are generated by RedSDK technology from Redway3D®. The GPU is used to render this modes.
Note: We suggest that you install the latest drivers available for your display hardware, as recommended by the manufacturer.
Note to Linux users: Hardware acceleration of 3D graphics on Linux systems is NOT supported on:
  • Intel® graphics chipsets / cards.
  • Laptops with dual graphics adapters.
