Trial mode
BricsCAD can run in trial mode for 30 days. After this period, you need to activate a valid commercial license.
Running BricsCAD in trial mode
Each time you start BricsCAD in trial mode, the BricsCAD Launcher opens, indicating the days left.
Do one of the following:
- Click a workspace to continue using BricsCAD in trial mode.
- Click the Activate button to open the License Manager dialog box, which allows you to activate a Single or Volume license or to use a Network license.
Setting the license level
When running BricsCAD in trial mode, all features are available. It runs as a BricsCAD Ultimate license.
The SETLICENSELEVEL command allows you to select a lower license level.
