Upgrading BricsCAD or extending your subscription (Single/Volume license)
Important:
- We strongly recommend activating or upgrading BricsCAD online.
- If the license was activated offline, you need to revoke it first. See the Revoke a BricsCAD license (limited operation) article for more information.Remember: Only 2 revokes are possible. For online activated licenses, deactivation and reactivation are unlimited.
Upgrading BricsCAD license online
Upgrading BricsCAD version
When you have purchased a version upgrade for BricsCAD you need to install the new version and launch it. A pop-up showing the updated version is displayed.
Extending your subscription
When you have purchased an extension for your subscription, a pop-up showing the updated expiration date is displayed after you launch BricsCAD. The pop-up is displayed only after your initial subscription expires.
Upgrading BricsCAD level
When you have purchased a level upgrade, you need to reactivate your BricsCAD key following the next steps:
- Launch BricsCAD.
- Run the LICENSEMANAGER command to open the Bricsys License Manager dialog box.
- Click the Manage License button to open the dialog box.
- Click the Modify... button to open the dialog box. Your key is already prefilled in the License Key field.
- Click the Ok button to reactivate your BricsCAD key.
Upgrading BricsCAD license offline
To upgrade your BricsCAD license when you can’t connect to the internet, follow the process described in the Offline/manual activation (Single/Volume license) article.
