AI Predict
The AI Predict ribbon provides suggestions based on your personal BricsCAD usage, and similar users. The AI Predict tab has two states: an empty state and a populated state.
You can add or remove the AI Predict ribbon tab by removing or adding it to the CUI file.
The AI Predict tab in the empty state:
- Sign Up
- The Sign Up button opens the BricsCAD Analytics Program dialog box.
The AI Predict tab in the populated state:
- Analytics Settings
- The Analytics Settings button opens the BricsCAD Analytics Program dialog box.
- Other Command Suggestions
- Displays commands used by other users with similar interest as yours.
- Personal Command Suggestions
- Displays the most important commands used.
Note: Panels will be populated from the first day of usage BricsCAD with commands based on your interaction with BricsCAD via Quad, command line, ribbon, menu, and toolbars. Also, not everyone will be eligible for all models, depending on how we categorize them.
- Next Commands
- Dynamically displays some predicted commands which could be used by the user after the current command.
