Performance and compatibility
BricsCAD V21 offers new and enhanced tools to improve performance and compatibility as you work individually or in a collaborative environment.
Selection Preview
Selection preview highlighting is deactivated during Pan operations, resulting in a smoother user-experience.
Xref Loading
Multiuser Version Control (BETA)
BricsCAD V21 introduces new multi-user version control functionality as a beta technology preview. This functionality enables multiple users to work on the same drawings, simultaneously. Drawings are stored in the cloud using Bricsys 24/7 and checked in and out from each user's local machine.
Access
Since this is Beta functionality, you must request access by submitting a support request.
- Log into your Bricsys account.
- Choose New Support Request.
- Open the BricsCAD menu and choose .
- In the Subject field enter: Access to VERSIONCONTROL Beta.
- Fill in the rest of the fields as needed.
- Choose Send Support Request.
VERSIONCONTROL Command
The new VERSIONCONTROL command offers the following options:
- Init
- Checkout
- Checkin
- Update
- Rename
If your account has not been granted access to the beta functionality, it directs you to a web page with instructions to request access.
Init
The Init option enables you to create a new multi-user project. Enter a new project name, keeping in mind project names are case-sensitive. If you enter a name that already exists, it prompts you to enter a different name.
Checkout
The Checkout option enables you to check out a drawing from your cloud-based projects. You must specify from which project you want to check out a drawing. Enter the project name, keeping in mind project names are case-sensitive. If you enter a project name that doesn’t exist, BricsCAD displays a list of valid project names and prompts you to reenter the project name.
After entering a valid project name, you must specify a version control folder for that project. The version control folder is the location on your local machine where your drawings are stored and synced with the cloud. The default location is drive:\Users\username\Documents\Bricsys247\projectname. However, you can specify any location. If the location doesn’t exist, it’s created and set under version control. If the location already exists it’s set under version control. If the location is already under version control, you are prompted to specify a different location.
Checkin
The Checkin option enables you to check in drawings from your local, version control folder to the cloud-based project. You can check in all files in the version control folder or you can commit modified and untracked files.
After specifying what to check in, you can enter a relevant Check In message.
Update
The Update option enables you to sync project drawings from your local folder with the cloud.
Rename
The Rename option enables you to rename a drawing that’s under version control.
DGN Export
A new DGNEXPORT command enables you to export the current drawing to DGN file format.
3D DWF Output
The 3DDWF command enables you to create 3D DWF or 3D DWFx files based on the value of the new DWFFORMAT system variable.
User Profile Manager
Start Menu Shortcuts
Start menu shortcuts now set the program folder instead of personal documents folder as the initial working directory. This change solves problems with installation under a system account where personal folders are not available.
