-ATTDEF command
Defines attribute data.
Alias: -AT
Note: This command is meant for use by macros, scripts, and LISP routines. To specify attributes with a dialog box, use the ATTDEF command.
Defines attribute data (used by blocks) at the Command line.
Options within the command
Define an attribute by toggling attribute modes.
- Toggle attribute modes: Constant = Off Invisible = Off Preset = Off Verify = Off Lock position = Off Annotative = Off Multiple Lines = Off
Constant – type C
- Off – users can change the value of the attribute.
- On – users cannot change the value.
Invisible – type I
- Off – displays the attribute in the drawing.
- On – hides the attribute
Note: Invisible attributes are not displayed nor printed, but can be displayed with the ATTDISP command.Preset – type P
- Off – prompts the user to enter values.
- On – inserts attributes automatically, without prompting the user.
Note: The value of attributes can be changed later with the ATTEDIT command.Verify – type V
- Off – user enters the attribute value once.
- On – forces the user to enter the value a second time to ensure the value is entered correctly.
Lock position – type L
- Off – users can move attributes using grip editing.
- On – locks the position of the attribute within the block reference.
Annotative – type A
- Off – creates attributes using a non-annotative style.
- On – creates attributes using an annotative style.
Multiple lines – type M
- Off – forces the use only of single-line text.
- On – allows the use uses multiline text.
- Tag name of attribute
- Specifies the tag of the attribute; this is the name by which BricsCAD identifies the attribute. You can use up to 255 letters, numbers and punctuation.
- Prompt
- Specifies the user prompt; this is displayed at the command prompt when the attribute is later inserted in the drawing. You can leave this field blank; BricsCAD uses the tag as the prompt during attribute insertion.
- Default text
- Specifies the default value and set the style and justification of the text, as with TEXT command. If the Multiple lines mode is on, you may introduce more text lines.
- Text start point
- Specify the start point of the text.
- use defined Style
- Specifies the name of the text style.
- Align on line
- Aligns the text between two points. The text height is adjusted to maintain its aspect ratio.
- Fit between points
- Center horizontally
- Centers the text’s baseline on the pick point.
- Middle (hor/vert)
- Centers the text on the pick point.
- Justification options...
- Accesses additional justification options.
- Height of text
- Specifies the height of the attribute text, unless overridden by the text style or justification.
- Rotation angle of text
- Specifies the rotation angle of the rotation text.
