AIOBJECTSCALEREMOVE command
Removes the current annotation scale from selected annotative entities.
Icon:
Method
Select the annotative entities you want to remove the current annotation scale from. The entity is then displayed using another supported annotation scale from the entity scale list in the Annotation Entity Scale dialog box.
Note: This command works only if the selected entity is annotative or if there is more than one annotation scale attached to the entity.
