-BIMWINDOWCREATE command
Creates a fully parametric window or opening based on a closed contour.
Creates parametric windows using as profile any entity such as a boundary, a closed polyline or grid.
Note: This command operates at the Command line.
Options within the command
- wIndow
- Creates a BIM Window entity. An opening in the solid on which the profile entity lies is created automatically.
- Opening
- Creates an opening in the solid on which the profile entity lies. The opening is created by a solid on the BC_SUBTRACT layer. This layer is frozen by default. Thaw the layer to select the opening.
- Panel type
Single
Double Vertical
Double Horizontal
Triple Vertical
Triple Bottom
Triple Top
Triple Left
Triple Right
Triple Horizontal
