BMSEQUENCEPANELOPEN command
Opens the Sequence Manager panel.
Opens the Sequence Manager panel to display it in the current workspace. The Sequence Manager panel appears at the same size and location as it did before it was closed or collapsed. Like any other dockable panel, the Sequence Manager panel can be either floating, docked or stacked.
Disclaimer
Sequence Manager is an experimental feature that may not yet be stable and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
