BOUNDARY command
Creates closed polylines from bounding entities.
Icon:
Alias: BO, BPOLY
Method
Begin creating boundaries by selecting options in the Boundary dialog box. Options allow you to pick an internal point, specify the boundary set, and detect islands.
  1. Pick points in boundaries
  2. Boundary tolerance
  3. Boundary set
  4. New
  5. Retain Boundaries as Polylines
  6. Islands
Allows you to specify a point inside an enclosed area for which you want to create a boundary. It temporarily dismisses the Boundary dialog box.
Boundary tolerance
Specifies the largest gap that can exist in the boundary for BricsCAD® to consider the area closed.
Note: When boundary tolerance is 0, no gaps can exist.
Boundary set
Specifies where BricsCAD® should search for entities that make up the boundary.
  • Use Current View: searches all entities in the current viewport.
  • Use Boundary Set: searches only the current selection set for possible boundaries.
New
Allows you to create a new selection set of entities that make up the boundary. It temporarily dismisses the Boundary dialog box.
Indicates how boundaries are retained. This option is read only.
Islands
Specifies island detection. An island is an enclosed area inside a boundary.
Nested
Treats every island as a boundary.
Outer
Creates a boundary only of the outermost entities.
Ignore
Ignores the innermost areas. A boundary is created between the outermost area and islands.
Original entities:
  1. Internal point
Resulting polylines:
Options within the command
Select entities
Allows you to select entities to use as boundaries.
Undo
Undoes the last internal pick point and continue picking points to specify additional enclosed areas.
