-CIVILPOINTEXPORT command
Exports Civil points to an external file via Command line.
Method
Select Civil Points in the drawing, indicate the point file format name, then the file name and location.
Note: The Export As dialog box opens when the FILEDIA system variable is ON.
Options within the command
- point Group
- Specifies the point group name to export.
- ? to list point groups
- Lists all available point groups in the drawing. You can copy/paste the name of it in the Command line.
- Enter point file format name
- Specifies the point file format name used for export.
- ? to list point file formats
- Lists all available point file format names. You can copy/paste the name of it in the Command line.
- Include additional point attributes that are not defined in the selected format
- Allows you to choose whether to include point attributes that are not defined in the selected format.
