CIVIL3DIMPORT command
Creates BricsCAD civil entities from an Autodesk® Civil 3D drawing.
Opens the Import Civil 3D dialog box which allows you to import AutoCAD® Civil 3D entities from a selected .dwg file, or to convert them directly from the current drawing.
The following objects from AutoCAD® Civil 3D can be imported, which are in BricsCAD® also created as Civil entities:
  • Cogo points and point groups
  • TIN Surfaces
  • TIN Volume Surfaces
  • Grid Surfaces
  • Alignments (both Alignments by PI and Alignments by Elements are supported)
  • Profile Views
  • Profiles (Vertical Alignments)
  1. Convert from current drawing.
  2. Select drawing to import.
  3. Select All.
  4. Layer name template for Civil 3D objects.
  5. Import native CAD objects.
  6. Import Civil 3D labels as blocks.
Converts AutoCAD® Civil 3D objects in the current drawing.
Enables to enter drawing path or click the Select… button to select the drawing manually.
Note: When either the DWG file is specified or the Convert From Current Drawing option is selected, AutoCAD® Civil 3D objects are listed in a tree view, organized by object type.
Select All
Enables to select all AutoCAD® Civil 3D objects in the selected drawing.
Enables to specify the Layer name template for imported AutoCAD® Civil 3D objects.
The following settings are available for defining the Layer name template:
  • <Type>: includes AutoCAD® Civil 3D object type in the Layer name.
  • <Name>: includes AutoCAD® Civil 3D object name in the Layer name.
  • <SourceLayer>: Civil entities are created on same layer as source AutoCAD® Civil 3D objects.
If you want to draw BricsCAD® Civil entities on Layers, which names will consist of three sets: the type of the source Civil 3D object, the object name and the name of the Layer of the source AutoCAD® Civil 3D object, you need to write the following text in the field:
<Type>_<Name>_<SourceLayer>
Enables to import native CAD objects from the selected drawing in addition to AutoCAD® Civil 3D objects.
Enables to import AutoCAD® Civil 3D labels as blocks from the selected drawing.
Note: AutoCAD® Civil 3D COGO points labels are converted to BricsCAD® Civil point labels.
