CIVILPOINTEDIT command
Edits Civil points.
Opens the Civil Point Editor dialog box that allows you to edit the selected Civil points.
The Civil Point Editor dialog box displays Civil points and their properties in a table.
Note:
- Click a cell to edit the content.
- It is possible to sort the Civil points by some of their properties.
- The Civil Point Editor dialog box is modeless. This means you can work in the drawing while the Civil Point Editor dialog box is available on the screen.
Right-click the selected point(s) to open a context menu:
- Zoom to
- Zooms in to the selected civil point.
- Pan to
- Pans to the selected civil point in the drawing.
- Select
- Selects the civil point(s).
- Copy to clipboard
- Copies the civil point(s) to the clipboard.
- Delete point
- Removes the civil point(s).Note: A warning dialog box opens to specify whether you are sure to delete the points.
