CONVERTGISTOOBJECTDATA command
Converts BricsCAD GIS data from the current drawing to AutoCAD® MAP 3D and Autodesk® Civil 3D Object Data.
Method
Specify the GIS Layer name to convert or convert all GIS Layers from the current drawing.
Options within the command
Convert all
Converts all the GIS Layers in the drawing.
Note: The Object Data can be viewed and edited directly in the Properties panel.
