GOTOSTART command
Opens the Start page.
Opens or activates the Start page.
In the Start page you can:
  • Create new drawings based on a specified template or open recent drawings through the Start tab.
    Note: The number of available recent files is controlled by the value of the RECENTFILES system variable.
  • Access BricsCAD® tutorials and sample drawings through the Learn tab.
    Note: Internet access is required.
  • Access the Third Party Application catalog on the Bricsys website through the Apps tab.
  • Have an overview of your most used commands and achievements through the Insights tab.
    Note: You need to join the BricsCAD Analytics Program to get insights.
