INSERTLAYOUT command
Inserts a named layout of a drawing, as a Block Reference, in the current Paper Space.
Select a drawing from the Select drawing dialog box and specify the layout name and the insertion point. A Block reference that replicates the entities in the layout will be inserted in the current Paper Space.
Note: The command is only available in Paper Space.
