-OSNAP command
Toggles entity snap modes.
Alias: -OS, ESNAP
Toggles entity snap modes at the Command line (short for "object snap").
Note: Entity snaps help you draw and edit precisely by snapping the cursor to the nearest geometric feature.
Options within the command
NEArest
Toggles nearest entity snap mode. Snaps to the nearest point on any entity.
Note: Can also toggle with the NEAREST command.
ENDpoint
Toggles endpoint entity snap mode. Snaps to the endpoints of open entities, such as lines, arcs, open polylines, and open splines.
Note: Can also be toggled with the ENDPOINT command.
MIDpoint
Toggles midpoint entity snap mode. Snaps to the midpoint of open entities.
Note: Can also be toggled with the MIDPOINT command.
CENter
Toggles center entity snap mode. Snaps to the center of circular entities, such as circles, arcs, and polyarcs.
Note: Can also be toggled with the CENTER command.
GeometriC cEnter
Toggles geometric center entity (GCenter) snap mode. Snaps to the centroid of any closed polylines and splines, planar 3d polylines, regions and planar faces of 3D solids.
Note: Can also be toggled with the GCENTER command.
PERpendicular
Toggles perpendicular entity snap mode. Snaps to the perpendicular of one entity to another.
Note: Can also be toggled with the PERPENDICULAR command.
TANgent
Toggles Tangent entity snap mode. Snaps to the tangencies of circular entities.
Note: Can also be toggled with the TANGENT command.
QUAdrant
Toggles quadrant entity snap mode. Snaps to the quadrant points of circular entities, such as circles, arcs, and polyarcs.
Note: Can also be toggled with the QUADRANT command.
INSertion point
Toggles insertion entity snap mode. Snaps to the insertion point of blocks and text.
Note: Can also be toggled with the INSERTION command.
POInt
Toggles node entity snap mode. Snaps to point entities.
Note: Can also be toggled with the NODE command.
EXTension
Toggles extension entity snap mode. Snaps to the intersection of open entities, as if they were extended to the point of intersection.
Note: Can also be toggled with the EXTENSION command.
PARallel
Toggles parallel entity snap mode. Snaps to the parallel point of entities. Allows to draw lines, polyline segments, xlines and rays parallel to another entity.
Note: Can also be toggled with the PARALLEL command.
INTersection
Toggles intersection entity snap mode. Snaps to the intersection of any pair of entities.
Note: Can also be toggled with the INTERSECTION and 3DINTERSECTION commands.
APParent intersection
Toggles Apparent entity snap mode. Snaps to the apparent intersection of entities in 3D space.
Note: Can also be toggled with the APPARENT and 2DINTERSECTION commands.
NON
Clears entity snaps.
ON
Turns all entity snap modes on.
OFF
Turns all entity snap modes off.
Note: Modes can also be turned off with the NONE command.
