account
translation
Bricsys Help Center
-PSETUPIN command
-PSETUPIN command
Imports page setup definitions.
Imports page setup definitions from another drawing through the Command line.
Note: Page setups define how a drawing is printed and are used by the PRINT and PUBLISH commands.
Method
Run the command to open the Select Page Setup From File dialog box.
Related commands
  • PAGESETUP command
  • PRINT command
  • PSETUPIN command
  • PUBLISH command
Related information
  • Standard Open file dialog box
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
