PARAMETRICSCALEEDIT command
Edits parametric scale operations.
Alias: PSCALEEDIT
Method
The command lets you edit the scale frame, elements selection, direction and linked behavior of an existing scale operation.
Enter the name of the desired scale operation, then select the parametric operation data to be edited.
Options within the command
Shownames
Lists the names of all the scale operations available in the drawing.
Selection
Lets you edit the scale frame and elements selection of the specified operation.
Direction
Lets you define a new operation direction by selecting its base and second points of displacement.
Linked behavior
Allows you to decide whether the entities will follow operation definition points when adjusted by other operations.
Note: The Linked property can also be turned On or Off from the bottom section of the Mechanical Browser. The On value is signaled in Parameters Manager and Mechanical Browser panels by the symbol ∞.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
