POINTCLOUDREGION command
Creates regions in a point cloud.
Options within the command
- Draw
- Allows you to select parts of the point cloud to convert to a region.
- Rectangular
- Defines a rectangular region.
- Convert
- Converts solids or crop solids to regions.
- Select point cloud entity
- If there are more point clouds attached in the drawing, it allows you to select the point cloud for which you can create regions.
- Enter region name
- Allows you to specify the name of the region.
Note: Press the Esc key to exit the command.
