-RENAME command
Renames entities via Command line.
Alias: -REN
Renames named entities via the Command line, supporting wildcards to adjust the entity selection.
Note: In the replacement pattern, the asterisk (*) wildcard expands to the end of the string (the wildcard is handled as max greedy). Thus, patterns like '*-old' (source pattern) and '*-new' (replacement pattern) cannot be used to rename or batch-rename entities (for example, renaming 'layer1-old' and 'layer2-old' to 'layer1-new' and 'layer2-new'). For that, a LISP routine is needed.
Important: It is not possible to change the names of attached files, such as images and external references, nor the following names:
  • Layer "0"
  • Linetype "ByBlock", "ByLayer", or "Continuous"
  • Text style "Standard"
  • Dimension style "Standard"
  • Multiline style "Standard"
  • Visual style "2DWireframe"
  • Material "Global"
  • Page layouts that have * as a prefix and suffix, such as *Model*
  • View detail style "Metric50"
  • View section style "Metric 50"
Options within the command
Block
Renames blocks.
Dimension style
Renames dimension styles.
LAyer
Renames layers.
LineType
Renames linetypes.
text Style
Renames text styles.
Table style
Renames table styles.
Ucs
Renames user-defined coordinate systems.
VIew
Renames views.
ViewPort
Renames viewport configurations.
