account
translation
Bricsys Help Center
REMOVESKETCHFEATURE command
Removes all sketches created for Sketch Based Features.
Method
Specify if you want to remove or not all existing sketches created when the CREATESKETCHFEATURE system variable was enabled.
Related commands
  • EXTRUDE command
  • LOFT command
  • REVOLVE command
  • SWEEP command
Related variables
  • CREATESKETCHFEATURE system variable
Related information
  • Sketch based features
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
