SECTIONVIEWS command
Creates section views for civil entities.
Icon:
Method
Select a section line in the drawing, or press Enter to open the Select Section Line Group dialog box for selecting one available section line group.
- Name
- Parent alignment or string
- Number of section lines
- Name
- Displays the name of a section line group.
- Displays the parent alignment or string.
- Displays the number of section lines.
After choosing a section line group, the Create Section View dialog box opens.
When select a single section line and Single section view option in the Command line, the Create Section View dialog box contains the Section line name.
Options within the command
- Multiple section views
- The Create Section View dialog box opens.
- Single section view
- The Create Section View dialog box for only one section line opens.
