SHADEMODE command
Specifies the shading style for the current drawing.
Specifies the shading style for the current drawing to be used by the SHADE command.
Options
Enter visual style
Choose the name of a preset visual style.
2dwireframe
Default display mode.
Wireframe
Wireframe, which shows all edges.
Hidden
Wireframe with hidden lines removed.
Realistic
Rendered with materials, if available.
Conceptual
Displays 3D entities with smooth shading and the Gooch shading. Gooch shading is a non-photorealistic rendering technique for shading objects, also known as "cool-to-warm" shading.
Shaded
Rendered without materials.
shaded with Edges
Rendered with contrasting edges, without materials.
shades of Grey
Rendered in shades of gray, without colors.
Sketchy
Rendered with rough edge lines.
X-ray
Rendered with semi-transparent faces.
Other
Creates a new visual style.
cUrrent
Keeps the current visual style.
