-TINEXPORT command
Exports a TIN surface via Command line.
Exports a TIN surface to a specified point file format file.
Method
Select a TIN surface and then specify a point file format name.
Options within the command
- Name
- Indicates the TIN surface name that will be exported.
- ? to list tin surfaces
- Lists all TIN surface names in the Command line.
- Point file format name
- Indicates the point file format name used for export.
- ? to list point file formats
- Lists the names of the defined point file formats in the Command line.
