TINFROMDEM command
Creates a TIN surface using points from a DEM (Digital Elevation Model) grid.
Icon:
Method
Opens the Select a DEM format dialog box to choose a DEM (Digital Elevation Model) file format.
The available DEM (Digital Elevation Model) file format are:
  • GeoTIFF (.tiff)
  • USGS Digital Elevation Model (.dem)
  • ESRI Arc/Info Binary Grid (.adf)
  • ESRI ASCII Grid (.asc)
After selecting the file, you can downsample the grid.
Options within the command
Would you like to subsample from grid [820,620] spacing (2.000) units to grid [410,310] spacing (4.000) units?
Allows you to decide whether to keep the original grid spacing.
Yes
Uses the suggested new grid spacing values.
No
Keeps the original grid spacing.
Set custom
Allows you to manually set the grid spacing.
