VPLAYER command
Changes the properties of layers in the current paper space viewport.
Allows every viewport to show a different set of layers.
Note: This command does not operate in model space.
Options within the command
List frozen layers
Reports whether layers are frozen in the selected viewport. In the Command line, the frozen layers are shown after selecting a viewport.
Color
Overrides the color of specific layers in selected viewports. A new color is specified by entering the RGB code and applied to the layers in the selected viewports.
Red, Yellow, Green, Cyan, Blue, Magenta, White
Specifies the color for the layers in selected viewports.
Truecolor
Allows you to specify the true color for the layers in selected viewports, by entering the values for Red, Green, and Blue.
COlorbook
Opens a color book by entering its name and allows you to specify a color name from the loaded color book.
Note: The COLORBOOKPATH system variable specifies the folder(s) in which BricsCAD® should look for color book files.
LineType
Overrides the linetype of specific layers in selected viewports.
LineWeight
Overrides the lineweight of specific layers in selected viewports.
TRansparency
Overrides the transparency of specific layers in selected viewports.
Freeze layers
Freezes specific layers in the current viewport.
Thaw layers
Thaws specific layers in the current viewport.
Reset layers
Resets frozen and thawed layers to their original settings.
New frozen layers
Creates new layers that are initially frozen when a new viewport is created.
Default visibility setting
Changes the default freeze/thaw setting for layers.
Frozen
Changes the layer’s default property to frozen.
Thawed
Changes the layer’s default property to thawed.
Specify viewport(s)
Specifies viewports to apply changes to.
All
Selects all viewports.
Select
Specifies a selection of viewports.
Current
Adapts changes to the current viewport.
eXcept current
Adapts changes to all viewports except the current viewport.
