VPOINT command
Changes the 3D viewpoint.
Alias: -VIEWPOINT, -VP, -VPOINT, VIEWPOINT
Changes the 3D viewpoint to change the view of the model trough specifying several options.
Note: It is faster, and easier, to use the LookFrom widget to change the 3D viewpoint.
Options within the command
Set view point
Specifies the viewpoint by entering coordinates in the Command line.
Rotate
Changes the viewpoint by specifying angles.
Planview
Displays the plan view of the current UCS. See the PLAN Command.
Perspective
Sets the perspective property of the viewport.
On
Turns on perspective viewing mode. Objects further away look smaller.
Off
Turns off perspective viewing mode, returning back to orthogonal viewing mode.
