WMFIN command
Imports data from a WMF/EMF file into the current drawing.
Alias: WI
Method
Opens the Select WMF/EMF file dialog box to import data from the selected file into the current drawing.
Options within the command
- Specify insertion point
- Allows you to choose the insertion point. You can also define it by picking the point in the drawing area.
- Specify X scale
- Allows you to set the X scale value.
- Specify Y scale
- Allows you to set the Y scale value.
- Specify rotation
- Allows you to set Z rotation value. You can also define it by picking the angle in the drawing area.
