WORKPLANEHIDE command (Experimental)
Hides a Work Plane.
Alias: HIDEWORKPLANE
Disclaimer
Work Plane is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
Method
Select a Work Plane in the drawing to hide it from the Model Space.
Note: The visibility of a Work Plane can also be controlled via the right-click menu in the Mechanical Browser panel.
Options within the command
- All
- Hides all Work Planes in the drawing.
