WORKPLANESHOW command (Experimental)
Shows a hidden Work Plane.
Alias: SHOWWORKPLANE
Disclaimer
Work Plane is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
Method
Select a hidden Work Plane temporarily highlighted in the drawing to control it's visibility in the Model Space.
Note: The visibility of a Work Plane can also be controlled via the right-click menu in the Mechanical Browser panel.
Options within the command
- All
- Shows all Work Planes in the drawing.
