Communicator for BricsCAD - Getting started
Communicator for BricsCAD® is an optional plugin for Pro and higher license levels of BricsCAD® that imports and exports 3D data between major CAD formats. Its high-quality conversions facilitate the re-use of 3D CAD data to improve productivity and reduce project costs.
Activating Communicator for BricsCAD®
After you have installed Communicator for BricsCAD® on your computer, you need to activate the software.
- Launch the LICENSEMANAGER command.The Bricsys License Manager dialog box displays.
- Next to Communicator for BricsCAD, click Manage License.
- The dialog box displays.
- Click Activate Trial to activate Communicator for BricsCAD® trial license online.
- Click Activate Now…. You can:
- Type a valid Communicator for BricsCAD® license key into the License Key field if you are using a single-user license.
- Type the Server name or local IP address of the license server if you are using a network license.
- Click the OK button.
The license is registered, and a confirmation dialog box displays.
- Read the text on the dialog box and click the I understand button.
Note:
- To activate Communicator for BricsCAD® license offline see: Offline/manual activation (Trial) or Offline/manual activation (Single-user license).
- To activate Communicator for BricsCAD® network license on the license server see: Online activation (Network license) or Offline/manual activation (Network license).
