Compatibility between Communicator for BricsCAD and BricsCAD
Communicator for BricsCAD works with a BricsCAD Pro license or higher.
About
The two first product numbers must match. For example, BricsCAD 22.1.xx is only compatible with Communicator for BricsCAD 22.1.xx. Previous BricsCAD versions (V21 or older) are not compatible.
There's one exception: For Communicator for BricsCAD V21, all BricsCAD versions are compatible, provided that the major version number is 21.
Note:
- Communicator for BricsCAD V22 installs and runs independently of previous versions.
- The compatibility between Communicator for BricsCAD and BricsCAD is always mentioned in Release Notes for Communicator for BricsCAD, under Versioning. The Release Notes for Communicator for BricsCAD are available from the download page.
We strongly recommend using the latest product version of the major version number.
