Elevation Analysis dialog box
Opens via: (only for selected TIN or Volume surface entities) Civil Explorer panel > Visual Styles tab > the TIN Analysis section > Elevation analysis > click the right side three dots
The Elevation Analysis dialog box allows you to define the parameters for creating the TIN surface Elevations Analysis.
- Options
- Color scheme
- Insert legend
- Elevation range
Options
Allows you to specify the parameters for creating the TIN surface Elevations Analysis.
- Create ranges by
- Allows you to choose between the methods of creating Elevation Analysis:
- Number of ranges
- Range interval
- Range interval with datum
Important: Depending on how you create the ranges, different properties are available.
- Color scheme
- Allows you to select the color scheme for the Elevation Analysis.
Choose between the available options:
- Spectrum
- Earth
- Hydro
- Gray
- Reds
- Greens
- Blues
- Custom
- Above datum color scheme
- Allows you to select the above datum color scheme.
- Below datum color scheme
- Allows you to select the below datum color scheme.
- Display as
- Select the TIN Surface elements used to create the Elevation Analysis.
- 3D Triangles
- 3D Contours
- Points
- 2D Triangles
- 2D Contours
- Datum
- Specifies the datum elevation.
- Base elevation
- Specifies the base elevation
- Number of ranges
- Specifies the number of ranges for the Elevation Analysis.
- Range interval
- Specifies the Range interval for the Elevation Analysis.
Color scheme
Displays the corresponding colors for elevations based on the selected color scheme.
Note: When you create a range using the Number of ranges option, you can edit the elevation values in the table.
Insert legend
Inserts the color scheme table at a specified location in the drawing.
Elevation range
Allows you to define a specific elevation range.
- Minimum elevation
- When activated, you can specify a minimum elevation value.
- Maximum elevation
- When activated, you can specify a maximum elevation value.
- Out of range values
- Allows you to define the color representation for elevations that have values outside the defined range.
