Manage Data Sources dialog box
Opens via:
  • SECTIONDATASOURCES command
  • SECTIONVIEWEDIT command > Edit Section View dialog box > Manage data sources button
  • Civil Explorer panel > context menu of a Data Sources > Manage data sources... option
The Manage Data Sources dialog box allows you to add or remove data sources from a section line group. The available data sources are surfaces, strings, solids, polylines, and meshes.
  1. Section line group
  2. Available data sources
  3. Selected data sources
Section line group
Displays the section line group name.
Lists all available data sources in the drawing.
Selected data sources can be added to the Selected data sources list by pressing the button.
Lists the selected data sources that are included in the section line group.
Selected data sources can be removed from the Selected data sources list by pressing the button.
Also, you can select the civil entities from the drawing, by pressing the button.
