Point Group dialog box
Opens via: CIVILPOINTGROUP command
The Point Group dialog box allows you to create or edit a Civil Point Group.
Note: Click a cell to edit the content.
Name
Allows you to enter the name of a new point group for which you will create a new filter or display the name of an existing point group.
Note: If the point group name is not defined, a warning message appears.
Allows you to enter a description of the point group or display the description of an existing point group.
Filter
Allows you to create a new or to edit an existing filter in which you specify the criteria for including and/or excluding points in the selected point group.
Note: You can add, duplicate or delete the filters.
Note: Once an individual filter is created in a particular drawing, it also affects all the points that are inserted later in that drawing.
The parameters used for filtering are:
  • Elevation
  • Name
  • Raw description
  • Full description
  • User attribute key
  • User attribute value
Specify point numbers to include
Allows you to enter the point numbers to be included in the specified filter.
Note: Points can be selected from the drawing by pressing the arrow from the right side of the field.
Specify point numbers to exclude
Allows you to enter the point numbers to be excluded from the specified filter.
Note:
  • If no filter is defined, a warning message appears.
  • It is possible to create a point group even if no Civil points are present in the drawing.
