Reassociate Entity Data dialog box
Opens via: REASSOCAPP command
The Reassociate Entity Data dialog box allows you to associate extended entity data with a specific application.
  1. Applications associated with Entity Data
  2. Options
Original application
Specifies the name of the original application.
New application
Specifies the name of the new application. Entities will be reassociated with this application name.
Options
Skip
Skips entities that already contains an item with the same name as the new application.
Remove the existing application before reassociating
Removes the existing application before reassociating.
