Render video dialog box
Opens via:
  • Animation Editor panel
  • -ANIMATIONEDITORPLAYBACK command
The Render video dialog box allows you to set the render options for your animation.
Render frame rate (fps)
Sets the frame rate of the video.
Resolution
Sets the resolution of the video by selecting it from the drop-down list.
File format
Sets the format of the output video. You can select a file format from the drop-down list:
  • avi (AVI Animation)
  • mpg (MPEG Animation)
  • wmv (WMV Animation)
Render quality
Sets the render quality of the output video.
  • Draft quality: for fast rendering.
  • Full quality: the current render preset will be used to produce the same result as RENDER command.
Start time
Sets the time position of the animation to start the render.
End time
Sets the time position of the animation to end the render.
Start frame
Sets the frame position of the animation to start the render.
End frame
Sets the frame position of the animation to end the render.
Frame images folder for FFMPEG
Sets the folder where the frame images will be stored.
Clear rendered frame images after creating a video file
Toggles the resetting of the frame images after creating a video file. When enabled, only files created during this rendering session will be deleted.
After clicking the Render button, the Save Video As dialog box opens to allow you to save the rendered video.
