Select Layouts to merge dialog box
Opens via: LAYOUTMERGE command (Express Tools)
The Select Layouts to merge dialog box allows you to merge entities from specified layouts into a destination layout.
  1. Layouts to merge
  2. Destination layout
  3. Type a layout name
Layouts to merge
Allows you to choose one or more layouts to be merged.
Destination layout
Allows you select a destination layout from the list.
Type a layout name
Allows you to type a layout name. If the layout does not exist, the Create layout? dialog box opens which asks you if you want to create the layout or not.
