Apple compatibility for BricsCAD
Apple introduces big changes with each major release of macOS. These result in a number of applications to break, including BricsCAD.
Note: The purpose of this article is to document the compatibility of new macOS versions. It does not list all old versions of macOS.
Support for Tahoe (macOS 26)
- BricsCAD V26: is supported with Tahoe
Support for Sequoia (macOS 15)
- BricsCAD V26: is supported with Sequoia
- BricsCAD V25: is supported with Sequoia
- BricsCAD V24: is supported with Sequoia
Support for Sonoma (macOS 14)
- BricsCAD V26: is supported with Sonoma
- BricsCAD V25: is supported with Sonoma
- BricsCAD V24: is supported with Sonoma
Support for Ventura (macOS 13)
- BricsCAD V26: is supported with Ventura
- BricsCAD V25: is supported with Ventura
- BricsCAD V24: is supported with Ventura
- BricsCAD V23: is supported with Ventura
Support for Monterey (macOS 12)
- BricsCAD V26: is supported with Monterey
- BricsCAD V25: is supported with Monterey
- BricsCAD V24: is supported with Monterey
- BricsCAD V23: is supported with Monterey
- BricsCAD V22: is supported with Monterey
- BricsCAD V21: is supported with Monterey
- BricsCAD V20 and older versions: are NOT supported with Monterey
Support for Big Sur (macOS 11)
- BricsCAD V25: is supported with Big Sur
- BricsCAD V24: is supported with Big Sur
- BricsCAD V23: is supported with Big Sur
- BricsCAD V22: is supported with Big Sur
- BricsCAD V21: is supported with Big Sur
- BricsCAD V20: only V20.2.11 is supported with Big Sur
- BricsCAD V19 and older versions: are NOT supported with Big Sur
Support for MAC hardware running Apple silicon
Since V21.2.06, BricsCAD (Mac) works on Rosetta 2 (Intel emulation on Apple silicon). A native build is planned for the future.
