How to PURGE the DGN linetypes from Microstation import
Symptoms
BricsCAD takes a longer time than AutoCAD® to handle/save drawings which contain DGN linetypes which also unnecessary increase drawing size.
Cause
The cause cannot easily be removed. There can be a lot of these linetypes due to previous bugs in AutoCAD® which caused accumulation of these linetypes. The recommended approach would be to purge the linetypes, only PURGE does not apply to custom entities such as DGN linetypes.
Solution
As a workaround, there is a compiled DLL file which purges DGN linetypes.
Do the following:
- Download the DLL and unzip the file.
- Right click on DgnLsPurge.DLL and ensure that it is not blocked.
- Launch the NETLOAD command and load DgnLsPurge.dll.
- Run the DGNPURGE command.
Note:
The sources for the DLL are listed here: https://through-the-interface.typepad.com/through_the_interface/2012/12/purging-unwanted-dgn-linestyle-data-from-an-autocad-drawing-using-net.html
