account
translation
Bricsys Help Center
AREAUNITS system variable
Area units
Controls a list of units used to display areas, if area properties are formatted with the PROPUNITS system variable. If empty, all areas match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
in ft mi µm mm cm m km
Related commands
  • UNITS command
  • -UNITS command
Related variables
  • INSUNITS system variable
  • PROPUNITS system variable
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
